Nun Replacement Time
The Nun on my 07 Summit is toast. How long has it on average taken the rest of you to replace it? Should I also put 440 nun in or put the same summit nun in?
440 x 2.
depending on the damage may want to replace the steel reinforcement at the PTO side as well. Remember with the 440 you can transfer more energy into the bulkhead, may want to stiffen this up as well.
FYI the only diff between the 440 and the 07 nun is the $70 reinforcement bent L shape at the front of the a-arms, you can order separately but it is cheaper if you don't The other 440 z shape reinforcements above the steering link don't come with the 440 nun and can be ordered separately as well.
