Numbers that work for me w/ the 3d box
Okay- these rip for me at 8lbs and 7500-10000k'
3500 6 2 00 00
4300 18 18 13 1
5100 19 28 18 5
5900 24 27 25 1
6700 32 32 31 4
7500 30 35 35 55
8300 25 35 35 83
acel 00 00 08
dcel 01 04 08
Once I get my box back are there numbers allready pre programed in or do you put them in? How much trial and error to get it running good?
Routter.. Are these all the windows now?
You don't need any negative numbers in the low RPMS?
4 #'s per window? Are you in super-tune mode?
and no more PSI high or low.
Nice to see BD trying to make it simple.
Does the new box settings come with explanations?
thanks
dc
There should be #'s programmed in the box when you get it back. They seem to be pretty close, but will surely need some fine tuning, as all sleds are slightly different, as well as riding variables.
The box does come pre-programmed. There was just a bit of stumble for me at 3/4 - WOT at 67, 75, and 8300 rmps. The same was true on decel. So these are my adjusted numbers. In most cases we're only talking a coupla' points.
Also, the box now ships in supertuner mode and the numbers I listed are: low, med, high and code a-d.
As I have posted before, I am a boost newbie; So most of this I am sure could be debated. One thing I do know, is since the new box I can now tell that this is how a sled on boost should respond.
