Want to sell as one lot so make offer - will not sell parts individually
These are the only parts I have - I am not a dealer so do not have any other new old stock parts
Qty PN Description Retail
Suspensions
1 0703-290 ARM,FRT.-LOWER-FAB-RH (BLK.) 79.95 95zr440,96-97ZR580,98 Triples
1 0703-291 ARM,FRT.-LOWER-FAB-LH (BLK.) 79.95 95zr440,96-97ZR580,98 Triples
1 0703-158 ARM,FRT LWR-RH-FAB 117.95 92-93 EXT, 93 Panther,Prowler
2 0703-407 ARM,FRT.-upper-FAB-LH (BLK.) 7.29 96-97ZR580,98 Trples
2 0703-337 A-ARM,FRONT UPPER-FAB 54.95 96-02 bear,96-97 ps, Panther
1 0703-106 ARM,FRT-UPPER-FAB 94.95 91-93ext, 93 Prowl, Panth
1 0703-648 SPINDLE,FAB.-RH MILLED (PS) 129.95 01-02 PS&MC,01-02 Z&ZL, 04-05 T660& Panther
1 0703-232 SPINDLE/HOUSING-MFG-***,Y RH 114.95 93-94 ext T-cat
2 0636-730 End Cap Kit 12.95
1 1604-756 EXTENSION, RAIL- MACH RH 151" MC 64.95
1 1604-757 EXTENSION, RAIL- MACH LH 151" MC 64.95
1 0705-228 SUPPORT,STEERING-ASSY 34.95 99-01 PS, Triples, Z, ZL, ZR, Pantera, MC/ 02ZR500
Electrical
2 3005-890 CONDENSOR, EXHAUST VALVE 104.95 01-05 500,800, 900
1 0636-766 THUMBWARMER KIT W/SWIT 32.95 97 Jag, Puma
1 3003-947 FUSIBLE LINK 15.99
2 3003-796 R/B 3005-185 coil 78.1 91 Ext
1 3003-882 R/B 0637-124 / Relay 34.95 91-97 580
4 3003-175 CAP,SPARK PLUG LB05EZ 3.49 86-91 fan
2 3003-946 LEAD, BATT PLUS 10.45 92-96 EFI
1 3004-398 CDI UNIT 377.95 94-96 EFI 580
1 3005-409 COIL ASSY, IGNITION 112.95 99-04 550,99-00 700, 570
1 3003-883 RELAY ASSY,CONTROLLER 48.95 91-94 EFI's
1 3004-483 COIL ASSY,IGNITION 148.29
1 0638-927 GAS CAP ILLUMINATOR 34.95
See below 0709-052 R/B 0637-010 51.42
1 0637-010 THROTTLE SWITCH KIT 90.7
Other
3 0636-148 Stud Kit 10.95
2 0636-149 Bolt Nut Std 10.95
1 1639-197 KIT,BRAKE LEVER -Black 19.95
1 0702-551 ADJUSTER, CHAIN-ASSY 39.95
1 0636-276 PUMP KIT,FUEL-ROUND 16.95 92-00 440-600's
7 0638-905 ROLLER KIT 51.95 95-96 440-600, & triples
4 0646-262 BEARING,COVER 12.95 97-99 Drive clutch
2 0687-120 CABLE,THROTTLE-EFI W/O OIL 21.95 00-05 600's
1 0687-037 CABLE,THROTTLE-VM38 52.79 91-02 w.38 carbs
1 0705-157 ARM,IDLER-STRNG-FAB 22.95 96-99 440-600
1 0645-228 SHAFT, DRIVE/PINION 75.89 96-00 Elec Start
2 3004-094 REGULATOR, FUEL PRESSURE 161.95 93-98 EFI - 580
1 0639-859 KIT, DECAL - HOOD - CARBON/BLACK 12.95
2 0603-901 SHOCK ABSORBER-FRT SUSP-RYDE FX (BIG BUM 139.95 97 Psextreme, T-Cat, Pantera
10 0639-430 KIT, AUX. WHEEL (GREEN) 69.95 97 Triple, Zl ZR440 ext
15 0107-598 BEARING,BALL-25MM 10.95 90-04 Rear susp.
2 0107-123 BEARING,1W/LOCK-(LARGE RACE) 32.95 74-01 Driveshaft
1 0673-030 BEARING,FRONT-PUMP {62/22RKB} 21.95 Watercraft
3 0603-454 SHOCK ABSORBER-FRT SUSP-RYDE FX (BIG BUM 139.95
1 1612-450 DEFLECTOR,EXHAUST-BLK 16.95
2 1639-167 KIT, RECOIL HANDLE - LARGE - PPL 1
2 0639-802 HOOK, HANDLEBAR - SHORT - BLACK 24.95
1 0639-405 Front Bumper Kit 209.95
1 0638-320 Front Bumper Kit 12.95
0604-309 SLEEVE,SHOCK ABSORBER 3.38
1 0608-044 BUMPER,TORQ.{2.600/2.700}-ENGINE-60 DU 9.06
1 4972-465 SHLD, PFP 2 AMBER 29.95
1 4932-460 DEFLECTOR,WIND '92-'93 5.95
1 4912-135 SHLD,DL CL 88-92 FF 26.95
1 4972-464 SHLD, PFP 2 SMOKE 29.95
Suspensions
Electrical
Other
