non starting Nytro mtx
jw3210
New member
I'm getting an error code 1 with the engine symbol, and the starter is just clicking, the battery is charge. This is a nytor mountain 2011.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p>
Any help would be appreciated.<o:p></o:p>
:face-icon-small-sad
Error code 1 is mostly a voltage problem (bad Battery) or bad ECU
The starter relay can go bad also.
If you are using a teather switch by pass it and retry.
Sounds like the relay. Very common with the Nytro. Before I replaced my relay I would cycle the key trying to start it a few times and it would kick over. If not the relay is in front of the battery. The terminals green and don't make contact take a look there.
thanks; do you know where the ecu is located if its not the starter relay?
Thanks for the location of the starter relay.
I jumped the starter relay and had a spark between terminals (unplugged relay an put copper staples so I could jump wires). Now the meter display is no longer working; do you know the location of the fuse that controls the meter display? Is there anything else that would prevent the starter from engaging the motor?<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p>
