extrovert drivers installation issues
I am in the process of trying to install some extrovert dirvers (anti-slip) onto the drive shaft. What I have noticed is the drive shaft is about 20" in length and the internal space within the tunnel is about 16". to get the drive shaft in/out, you have to angle it and swing it in/out. I have the extrovert driver in place on the the drive shaft, but when trying to swing it into position through the tunnel, there does not appear to be enough room to swing it into place. As the extroverts sit slightly wider than on the drive shaft than the original 'nub' driver, when trying to swing the drive shaft back into position the added width of the drivers does no allow for it to angle enough to swing in.
I am hesitant to take apart the frame to get the added width to slide the drive shaft in. Sliding the drivers once they are on the mounted drive shaft does not seem likely either due to the incredbile squeezing pressures of the driver on the drive shaft (press fit).
Any guidance on this would be most helpfull...
Thanks
