No Reverse!
SuperBad
Banned
I'm putting my 2014 Pro back together and everything seems to be fine. Problem is that there is no reverse. Runs forward just fine but when I push the reverse button, nothing happens. I've checked and it seems all my connections are good. I did put in a brand new TPS because. I just bolted it in because I don't have a TPS tool. Man I need to get out and ride. Any ideas?
Tps needs calibrated/adjusted
I know this is common with sleds that die when the reverse button is hit, but I've never seen it where the button does nothing. Sled just keeps running. I'm pretty sure the RPM range is low enough too.
Sounds like your ecm thinks your throttle is slightly opened and it's not letting it go into reverse
The Tps needs to be fully calibrated. I would not ride the sled until you perform the calibration. Fueling for the CFI-2 is largely based on TPS input.
As the others have pointed out, the TPS is probably open enough that the ECU is seeing an open throttle and locking out the reverse function.
Time to take it to the dealer, or find a PCV or Bullydog that you can use to set the TPS to spec.
I'd check the wires going to the perc button first. One time my pro wouldnt go into reverse. Ended up finding out that if i turned the bars so far to one side that the reverse would work. Found one of the wires for the reverse button were chafed.
reverse worked then he installed new TPS,
TPS HAS NOT BEEN CALIBRATED
now reverse doesn't work. I wouldnt waste any time looking at anything Until the TPS has Been calibrated.
