Hello thanks for your attention!
I have a 2013 800 pro rmk! i have a problem with right cylinder!
i will tell the story how this problem appeared!
In november i put a silber turbo 2013 and went for a ride on the first day i broke my drive clutch- it got stuck under load! other 3 days i have been putting oil on weights every 2 miles to keep it working!
When i came home i gave it to rebuild after installed on snowmobile again but it was assembled wrong it caused to track spin even on idle!
and my engine shut down with popping sound from turbo!
in 2 month i returned home and put a finally repaired clutch back! it worked good! but i spot that my engine is running badly! i gave a short ride and spot that the right cylinder did not work because exhaust temperature was very low!
here is what i have done after!
1 changed the spark plugs
2 check the spark, compression -OK
3 changed fuel filter
4 put stock ecu setup back
5 cleaned exhaust valves
6checked intake reeds-OK
the spark plug seems to be wet ( but maybe it is oil ) there is compression and spark on this cylinder but it still does not work!
please help me out maybe some one had the same problem?
