Just got my 2016 rmk back from dealer after recall fix. The headlight is not turning on, the grips are not heating and the high beam is not working. I decided to swap relays around after reading to see if it was possibly a bad relay. So one relay is bad because in the dash does not work in one of the times i swap relays. Can someone tell me what relay controls each circuit? Also does anyone know how I can diagnose the problem. It seems to me I have 2 circuits, chassis power and load shed relay not working. I found one 2 Amp fuse above the clutch and it was not blown. Thanks in advance!
