Nitrous on XP
T
tube
have a boondocker kit coming for an 08 xp, going to run about a 25hp shot, are there any issues with this?
how much work to insatll it. do you leave the same clutching.how does it work when you hit the button you gain a couple hundred rpms or what?
I have it on my '09 XP- it works pretty good. Had problems with my '08 and '09 as well hitting the rev limter when I hit the button, so I got my ECM reprogrammed to raise the rev limiter and it works better now!:beer;
What will it rev to with the limiter raised???
Isn't that kinda high for the 800r to rev above 8550???
Chaz
Nitrous is fun
I have ran a couple boondocker kits one my m7 and now one on my xp. The xp kit works great but I recommend getting the regulator kit as well, It just makes it consistent. I used to take a butane torch to the bottle on my
m7 and that was a pain in the azz. As far as over revving when I get to a hill I just click my primary clutch down one or two clicks(depending on what shot I am running) Over revving that much your not in the range where that motor makes power (but at 8700rpm it probably sounds really fast). Nitrous is ton of fun, nothing like getting stuck straight up and down. Good luck
And beware that the lines from the manifold to the dpm do not get pinched in anyway. Its a crappy reason to buy a motor!
I run nos on 08 xp run on clicker 3 when on button generally have to clicker down to one.
