NGK CR9EB For Big Chute/Super Chute
E
Evolution Powersports
Some have experienced misfire issues under the elevated boost levels of the BC/SC pump gas/100 Octane kits. These issues have been cured by changing the spark plugs and adjusting the gap.
The recommended spark plug for these kits is:
NGK CR9EB plugs gapped to .020
When installing, make sure you do not pull the wire out of the spark plug cap inadvertently. This will also cause misfire issues.
What is the difference in this plug vs. the stock plug and stock plug gap? Is the Iridium version(cr9eix) of this plug better yet?
I was one of those "some people". Thanks to the ultimate in customer care, my sled is now 0 to I think I just crapped my pants, in under 3 seconds - LOL.
Sent an e-mail to WKM describing the problem. Shortly after I got a call from Jim at EVO. Received a clear and concise check list and recommendations.
Further to that, got a call the same evening to insure sled was running to my satisfaction.
Signed
Darn Happy EVO Customer!
Yes. On NGK plugs and most others the higher number is cooler. The heat range is simply a measure of how quickly the spark plug dissipates the heat from the last cycle. Boosted motors or any with high cylinder pressure require a cooler plug to ensure the plug has cooled enough not to light the next cycle prematurely (detonation). The tighter gap makes sure the spark is not blown out ....so to speak.
