New WCS Yamaha Nytro Front Suspensions
W
Our kits are now available and ready to ship. The new ski stance is 39" center to center. The turning radius is increased by 10-12 degrees and the A-Arms are 4130 Chromoly Steel that are Tig Welded. The Spindles are 6061 T6 Billet C&C Machined Aluiminum. The front suspension uses all O.E.M. Bushings, sleeves and tierods. Two new upper and lower rod ends and aluiminun spacers connect the spindle to the new A-Arms. This kit also eliminates the sway bar (Fox Float Shocks Reccomended). The left & right spindles along with upper A-Arms are interchangeable from left side to right side. The kit save 8lbs-10lbs over the stock Yamaha Nytro front suspension. (Our kit weighs in at 15 lbs ! ) All kit prices are raw steel or powdercoated.
Suggested Retail: $799.95 Free freight to the lower 48(DEALERS WANTED !)
Colors available:
Yamaha Blue
Yamaha Red
Yamaha Black
Yamaha Silver
Yamaha White
Raw Steel
PM or call for more info or if you have any questions. 559-392-1182
Picked up my front end last night, Quality,quality stuff!!! Great job guys, keep up the good work!! Not like it matters cause ntytro,s are heavy anyway but this front end is LIGHT!!! Very impressed with the Tech, work on this one!!!! THANKS!!!!
WCS Nitro Front End
Got my front end yesterday. Quality craftmenship. Installed it last night. Fit better than the stock stuff & and a lot lighter. Great job guys.....
Can't WAIT!!......
to get my suspension!!! It should be here tomorrow and I will work on it over the weekend (hopefully if it comes).Once I get it on I will post my pics.
Thanks again Sean!
looks like you copied timbersleds stuff
Hey dexter. Only so many ways to build a A-Arm,No sway bar mount. As for the spindle. It is billet aluminum. 2 peice. Universal left & right. Different upper rod end. Different ski mount. Uses OEM Bushings and sleeves.
So......Not copied. Improved.
Thanks for your comment
Comparison?
Heres a email I recived from a customer..
"Post this for all the **** saying all you did was copy alans kit,
notice every spindle is bent in the middle because it oversteers and
hits the heim joint ultimately causing the spindle to colapse in the
middle? Also notice where the upper a arm mounts is all tweaked from
lack of support? The only way products continue to improve is by
taking the best offerings available pointing out there weeknesses and
improving on them. Or give me a day in the rocks and trees and I'll
show ya where the problems are! LOL . Ttul8r"
