stuff to know
if you are fine putting the gas in it leave it and run it.
In my opinion you will have trouble running a 2860 down to safe levels for pump fuel. you can but will end up with spongey lagy performance. you cant just turn it up and down based on fuel as you will also need to change clutching. The controller is more to adjust for elevation change once you are set up.
GET A TETHER if it doesnt have one put one on even if its a cheasy $20 one they dont like being upside down especially if running, I like the oft with the crank vent shut off, prevents the quart of oil in the motor from draining out. If you do have it upside down allow it to sit rite side up for a few minutes before starting check the oil to make sure there is some in the tank, then allow it to idle for a bit to get the oil back where it belongs..
the rear suspension will work they are super heavy and the tipped rails will make it run on the back bumper. Ice age can make flat rails for you that will help with the transfer. Plus you can plan ahead a bit and have them make the rails to fit a second suspension so you are ready for an upgrade down the road.
if you are wanting to change from race look at the shim between the clutches there should be a tag hanging out that says boondocker, cant remember what the shim measured, then try to tell if they split the gasket or put one top and one bottom, the gaskets are around 17thou. crushed makes a fair difference in compression. Split your compression is 9.4 to one with two gaskets you are down to 8.8 if I remember correct. there was a really cool and handy calc on here to figure fuel requirements and guessed power..
sory for rambling julio
