Is there anything wrong with the Edges?
If you want to be nitpicky,
1. the tunnels crack underneath the foot well when you hit a rock, and also underneath the black side trim towards the tunnel tail
2. steering column is weak in 2002 and requires reinforcing
3. the crankcase doesn't have have an oil drip hole that drops excess oil down on the PTO bearing, which is usually the first to go
4. the high beam switch goes out and causes all kinds of engine problems
5. the engine rips the front engine mounts apart causing twisting of the crankcase and crankshaft failure
6. it weighs as much as a pregnant elephant
7. the tail light cuts down the available hand holds on the rear bumper to practically nothing
8. the cylinder head neatly holds enough air due to the design of the concealed fins on the bottom side, to float the sled when you attempt to sink it in a lake
9. the stock polaris tracks leave a lot of room for the after market tracks to improve upon, like the camoplast challenger which is at least 50% more efficient
10. the optimum limiter strap position does not have a factory hole to bolt it into position. With #1 position being all the way out, a hole at the 1 1/2 position is optimum.
11. and of course the cranks do not last like an arctic cat
