hey guys. first time posting in the IQ section. drove 10 hours and picked up my first rmk!!!
had some questions. whos doing what. ive read on here and other sites some info. havent found any real clear answers
besides properly checking for clutch alignment, cleaning, balancing, what are people running for setups? weights, springs? pulling the foam of the panels surrounding it?
im considering side panel lower venting. on the exhaust side does that metal heat protection plate get removed? is it ok to remove and maybe put heat tape on the panel just to be safe?
any gains from a SLP air intake kit? or pulling the silencer tubes out of the stock box?
i also noticed one of the a arms was replaced with a shift a arm with that other bracket of the back of the arm. are these a arms different? seems that the side with that shift a arm has the spindle at a different angle and creates a hard spot on the shock sort of say? i know the part number are different and they dont list the arms as being interchangeable.
read about guys running a resistor on the airbox temp sensor to help with the mild temp mid range bog? any info posted on that?
thanks guys!!
brad
thanks guys!!
brad
