NEW PRODUCT: TIMBERSLED/FOX: FLOAT3 EVOL KASHIMA.
Timbersled
YOU SEE IT HERE FIRST!!!
Exclusive to Timbersled.
The 2014 FOX FLOAT3 EVOL with KASHIMA-COAT.
This all new shock represents the evolution of FOX FLOAT technology incorporating the evolutions of the negative air spring, plushness and bottom out resistance of the EVOL chamber chamber and new technology like Kashima coat and Bleed shim pistons that give excellent damping control for the performance enthusiast.
With the new bleed shim technology incorporated in this shock, careful valving selection and EVOL features.. we found that there really is no need to have valving adjustability in this shock for 98% of the riders. In fact, we have noticed that many riders with R-EVOL and X-EVOL shocks had them adjusted outside of the optimal setting simply because it took so much time to learn and setting and tune. With this shock, simply set your main and EVOL pressures and GO HAVE FUN!!
Ran a set of these Kashima coated beasts last year, and they flat out work!! Good work integrating them into your kits Timbersled!!
