Hey guys i wanted to give you guy an inside scoop of a pretty cool fuel box that has been under lock and key for about 9 months.
The prototypes are complete and they are all ready to be realesed. Snowest is the first place to hear about these.
This box is built by bully dog. It is a monitor/gauge style fuel controller.
The difference between this controller is you buy the monitor/gauge assembly. The package comes with all the wires and stuff you need to hook it up. It will monitor all the stock parameters that the stock ecu uses for fueling and ignition correction. Tps,deto (both cylinders), rpm, baro, engine coolant temp, speed, battery voltage, iat, ignition (both cyclinders) injector duty cycle.
This kit is ready for polaris now and others will be coming down the pipe. Doo and Artic cat.
Ok now once you have no purchased the gauge/monitor kit $499.00 us. There is an option to buy an unlock code from bull dog for $200 and we will sell you a map for your setup for $300.
The extra mapping will take us some time to get it all lined up. After a reflash is made for your set up. the mapp will be loaded to a mini SD card and loaded into your stock ecu. Now the map will only work or your ecu. the encryption will be locked to that ecu.
The mnitor package will be able to be used on different sleds but only one at a time. There will be a cost of a new mapp and set up. Unless it is the same year sled, using the same recipe.
Now before everybody goes and freaks out. Every body is still getting there feet under them. We at Turbo Performance have the monitor packages and can get them at any time. Which By itself this is a cool gig. We will need a little time to get all the mapping out to the general public.
Like always feed back is always welcome. As always we are all ears in how you guys feel and what will help you have the best riding experience.
Give me a call if you have any questions
Turbo performance
801-807-8046
www.turboboys.com
info@turboboyz.com
turboperformance@q.com
Turbo performance
801-807-8046
www.turboboys.com
info@turboboyz.com
