New Product announcement K MOD T3 rear kit
KMOD
The new coupling rear kit with K Motion
• For 163 and 174 T3
• Full mobility with 4 degree movement and lock out capabilities
• 4 position quick coupler
• Raptor 20 position compression clicker shock with dual rate spring
• Tig welded chromoly lightweight rear arm
• Replaces rear arm, shock, and torsional springs
• Uses factory rails and front arm for cost savings
• Keeps more track in the snow and trenches less
Harness your turbo power for full control
[/IMG]
Will it work with non t-3 skids? Have a 14 x with a 3 inch and turbo and this would be very useful.
I only have fit the 163, and 174 T3 so if the rail is the same then yes it should go right in the same position, we use a different drop bracket adapter if your drop bracket is the same as the XM.
Kevin
