Skinz ran this hood on their machine all last year and did not burn up one belt. The heat reduction is significant and the airflow through the hood keeps everything cool. The intakes in the hood now become vents that flow air out of the highest point in the hood preventing the chimney effect of heat trapping. They relocated the mass air flow sensor into the cold air intake at the nose of the machine and dramatically increased the area of the intake to allow more and constant cold air intake. The air no longer has to route through the ducting where it gets heated from the pipe and then make a U turn to get into the throttle bodies. The hood is all open and allows air movement along with deleting the headlight. The customer has the option of adding holes or additional venting in the open areas. All the panels install just like the OEM and fitment is exactly the same. There is no modifications necessary and the OEM hood can go back on the machine when the customer sells the machine or wants it stock again.
This will NOT fit the Turbo's but Skinz is building one that will!
Price is $499.95 Retail
http://www.sledsolutions.com/store/product_info.php?products_id=1214
These will be available in the next 3 weeks.
Thanks,
Paul
![SPGArcticCatAirframeHoodProClimbweb.jpg](http://i481.photobucket.com/albums/rr172/SledSolutions/Product%20Pics/ProClimb%20ProCross/SPGArcticCatAirframeHoodProClimbweb.jpg)
![ArcticCatProClimbACMF250-BKweb.jpg](http://i481.photobucket.com/albums/rr172/SledSolutions/Product%20Pics/ProClimb%20ProCross/ArcticCatProClimbACMF250-BKweb.jpg)
Thanks,
Paul
