Let me know if you like this type of info!
*** Attention Polaris 850 Owners ***
Breakdown of what changed on the 2020 mid season update flash #4019752
This Tune is Live in the Torque Link system already.
Some of the major changes vs the 2020 flash-
1. P and Mil codes - 1 turned off
2. Break-in minimum RPM - lowered to 3500 vs 5500
3. EV Mid - opens to mid position sooner ie lower RPM in low TPS zones
4. Fuel EV closed - modified richer and leaner in spots
5. Idle fuel modified
6. Idle ignition modified
7. Startup fuel modified
8. Ignition EV closed - less advance at very low tps.
9. Knock Ignition retard limit lowered
10. Knock Fuel add limit increased
11. Oil Ratio - Much leaner oil ratio on decell
If you would like to see the exact changes they are available in the Torque Link Developer package for the Polaris 850.
Remember when the "online experts" start telling you what is in the flash you saw it here first.
Number 1 question so far-
Q Will the new update be faster?
A They should be identical output at full throttle. 2020 vs the 2020.5 update there is no EV open fueling changes here are the tables in comparison mode. 2020.5 vs 2020.
![850 20 update comp 1.JPG 850 20 update comp 1.JPG](https://www.snowest.com/forum/data/attachments/287/287223-b462b8a71614d186198bd76e09a8483a.jpg?hash=tGK4pxYU0Y)
![850 20 update comp 4.JPG 850 20 update comp 4.JPG](https://www.snowest.com/forum/data/attachments/287/287220-64760115582ece2cf134878cbec3e140.jpg?hash=ZHYBFVguzi)
![850 20 update comp 3.JPG 850 20 update comp 3.JPG](https://www.snowest.com/forum/data/attachments/287/287221-f258c55296ac7f1785563c84b6ffca4d.jpg?hash=8ljFUpasfx)
![850 20 update comp 2.JPG 850 20 update comp 2.JPG](https://www.snowest.com/forum/data/attachments/287/287222-06dd3aad231f4a2a6348dbf9ac574f62.jpg?hash=Bt06rSMfSi)
