New mtn fit vents
R
RidnHigh
For all of you who still have the original console and wanted vents for them like on the new stirrups...here are some easy options for ya. All you have to do is remove the door or for the people who didnt have the door on both sides remove the door and the plate and you can mount these. These are one offs in white, they will come in silver or black abs...they slide behind the pins that the doors open on so if you ever wanted to take them off and put the door back in you can. Dont mind the slp rear vents on the side panels :-) NO Cutting....contact Bill and Mtn Fit Hoods to get them ordered....
Mountainfithoods.net
Also i just ordered some vents from mountain fit and you have to drill your own mount holes in the vents, did yours come with pre drilled holes?
Yes all the vents you have to drill rivet holes in, i dont know any company that has them pre drilled...You really dont even need the bottom two rivets because the bottom edge slides in between the console and the two pegs you can see that hold the door on. But all sets will come with all the rivets...
PRICE! $30.00 for PAIR either ABS or Aluminum...Clutch Side Comes with Scond Layer of Prefilter on too....
Bill is the man..i love dealing with him...great products and great guy..
always a pleasure..
so with this you were saying to can still have the door on over it???
also does this completely block off any storage you had there
There is like a half inch tab all the way around inside the door space that yes you can still rivet too....just open your door and youll see it.
No you cant still have the doors on with the vents but if you wanted to go back to having the storage you can drill the four rivets out and re install the door and bucket...so yes it does completely block off the storage that you have...
on a side note, you do have to remove the plastic bucket from the console to actually have air flow...super easy to do, just snaps out, so the only imperfection or alteration that you will have in the console is the 4 3/16 rivet holes if you decide to return to stock....
BTW stock sucks...:):beer;
:beer;:D
