New M7 Clutches Low RPMs
B
Blueside
New member
Nov 30, 2007
81
3
8
36
Kitimat BC
www.blueside.ca
So I managed to pick up a 05 M7 EFI 162" pretty cheap a few weeks ago, was in a hurry when I bought it and didn't go through the clutches very well.
Anyway long story short, when I got it home there was a bad roller on the primary and the secondary looked like someone was trying to spread the sheaves with a pry bar.
Starting fresh.
I picked up a "upgraded" primary (AC new part) and BD 10.4 sheaves, after reading what seems like endless information on here regarding set-ups I bought a new Orange M8 Spring with BD High Temp Rollers and the BD deflection nut. For the primary I went with the Gold AC Spring and 70g weights, with an M8 belt.
Seems to be stock, except a MBRP Can, I've heard stock is the way to go, I'll have a look and see if I can get one.
Was riding at about 3400' last weekend and RPMs topped out at about 7400. I think I should be around 7800RPM? It held RPM well on pulls up hills but seem like it was hitting a limiter at WOT (like a wah-wah-wah) sound. Just wondering if this sounds like a simple case of dropping weight 66-68ish? My next trip will be out to Mcbride (hopefully we get some more snow) 6000-7000 I believe should I drop even more?
Also, I read somewhere that these motors rather a lower octane fuel, any truth to this??
Also completely unrelated but are there many differences M7-M8 chassis wise? can I put a 08-09 M8 engine in this or is heavy modification required, I'd rather buy a used engine rather than a BB as hopefully I could keep the Electronic reverse from a newer engine.
Thanks you guys are always so helpful!
Rixster
3,781
651
Springville, UT
Yeah the m7 liked 88 octane. 70 is way to heavy IMO. I would bet you need to be more in the 62-65 range. and yes, as you gain elevation you need to lose weight in order to keep you rpm.
manlye
480
106
I have 67.5 on a 900bb at 10-12k 70 is way to heavy
A
arctic2009
1,864
670
Minnesota
Starting fresh.
08-09 engine will not fit without some modification.. not worth it imo. just buy a big bore kit if more power is what you are looking for.
Try swapping out the Arctic Cat gold spring for the Polaris straight gold spring. It has a lower start rate but the same finish rate as the cat yellow white spring (which is stock for an M7) 70 gram weights are recommended for 3-6k feet but your cat gold spring is a little light on finish rate which could be your problem with not getting proper R's. If you would rather stick with the cat gold, drop a few grams and go from there.
D
diggerdown
3,452
677
Deer Park Wi.
Throw a shim about 1/8" thick in the spring cup before spending more on weights. That should give you 2 to 300 R's. Cost nothing to try. Don't shim so high you don't have enough cup left to keep the spring retained.
Cat00
85
Im Running cat 0range Black spring and 66g weights holding 7800-8000 rpm all day on my m7
