sledhed88
I jusat finished the install on my M7. Twisted race kit
The sled sat for over 6months with an empty fuel tank. I can pour fuel in the cylinders and it will fire. There is spark. I couldnt get the pump primed with over 100 cord pulls, so i used a battery and it work fine. Filled the system, when i pour fuel in and fire it, it will read 40lbs quick then drop down to about 25ish pretty quickly after. Pulling on the cord to try to start, will bring pressure to just above 30.
This uses the capacitor/rectifier setup.
I changed the connection off my fuel pump, cause the kit didnt come with the same connector. Shouldnt matter ??
the vertical slat on rectifier thing is red from fuel pump and goes to the cap.
the - across (top right) is black from fuel pump and goes to cap.
top left is ground from power supply
bottom right is power
is that correctly hooked up
Im not too sure what else would be wrong.
The O2 gauge lights up when i pull the cord. Should the attitude box flash any lights when pulling it over, or only on start up. I cant remember.
Thanks any hellp appreciated
