New in Box Silber Turbo kit for 2012Pro $3800
Matte Murder
New in Box Silber Turbo kit for 2012Pro $3700
Selling my 2012 Pro never got a chance to put the new kit on. It is brand new in the unopened box ready to bolt on. This is absolutely the best deal on a Turbo kit for your Pro. When you consider you are getting the clutch kit and gauges too the price is pretty ridiculous. Need the money for snowchecks.
Silber Turbocharger custom engineered for 800cc two stroke engine
Billet waste gate, with low psi spring and standard psi spring included
Oil tank mount with roll over valve to eliminate smoke when upside down
Aluminum Oil tank, with sight tube.
Custom threaded and dual vented oil cap
Cold air intake, with stainless filter cage.
Stainless filter clamps
2.5” Exhaust down pipe with muffler
Socket head exhaust bolts
Pipe to turbo stinger, springs to stock pipe( no welding required).
Stainless turbo inlet gasket
Custom micro military grade oil pump
Pre cut and assembled oil lines, filter and fittings
Turbo coolant hoses and fittings
charge tube
Billet Boost controller
T bolt charge tube clamps
Black charge tube couplers
O ring fitted air box, with intergraded Blow off valve.
Billet Throttle body boots, with intergraded fuel injectors
Plug and play fuel control box, no splicing or wire cutting.
Boost Gauge
Innovate wideband gauge
Aluminum handle gauge mount bracket
All nuts, bolts and springs.
Precut boost lines and fittings
Turbo clutch kit with adjustable weights
