Introducing the latest innovation from Four Stroke Solutions LLC!
The Roll-Over Valve Control Module or ROVCM!
The ROVCM is engineered specifically for Four Stroke Solutions LLC Gen 3 Roll-Over Valve kits. Custom engineered and made for controlling roll-over valves, the ROVCM contains a micro-controller and uses pulse width modulation technology to control the roll-over valve. Pulse width modulation is very precise and the output from ROVCM is consistent under a wide range of temperature/battery conditions!
Up to this point Roll-Over shut-off valves have been controlled by direct battery voltage. Battery voltage can vary with ambient temperature, battery age and battery rating. The ROVCM takes roll-over valve performance to the next level! By commanding the shut-off valve to close faster/stronger, reduced current draw once the valve is closed, and offering a built in battery voltage monitoring system.
Shut-off valves are an electro-mechanical device and have different power requirements, depending on if the valve is closing or remaining in a closed state. By using pulse width modulation control the ROVCM is able to vary its output to valve to provide the fastest possible valve closure time, while at the same time reducing current draw by approximately one third once the valve is closed!
The ROVCM also has battery voltage monitoring/run down protection. The ROVCM has an internal timer and monitors battery input voltage. The ROVCM is designed to help prevent an accidental battery discharge, from leaving the Roll-Over Valve turned on by mistake. When the Roll-Over Valve is turned on, an internal timer inside the ROVCM starts. After the Roll-Over Valve has been on for approximately two hours, the ROVCM will start monitoring the battery voltage to the unit. If the battery voltage drops to approximately 12.1 volts, the ROVCM will shut down the Roll-Over Valve to help prevent further battery drain!
The Four Stroke Solutions LLC ROVCM is ideal for,
Riders who sled in extreme conditions or “get ejected” from the sled at a rapid rate!
Snowmobilers who ride in extreme cold conditions!
Sleds with light weight smaller batteries!
Anyone who might forget to turn off the ignition key at the end of the day with tether cord pulled!
Link to Q+A page http://fourstrokesolutionsllc.webs.com/highperformancerovcm.htm
Bill
Bill
