New Belt Question?
Please tell me that my new 3211080 belt isn't shot already (see pic)! I installed today and went for a short ride to break-in and noticed from the start that my sled was creeping/would squeal at stops. Went back to the garage to put old belt back on and noticed a small piece of one of the top cogs missing....Will the belt still be ok to run if primary belt to sheave clearance adjusted/belt deflection set correctly?
Thanks!
Mark
It is hard to say just looking at the picture. You should measure the belt width at several different spots on the belt, with a calipers. If it is hour glassed it wouldn't be something I would use (maybe as a spare). If it measures the same all around, including the bad spot, I would scrub the glazing off, and try it , after adjustments are made. It may be okay, if it doesn't vibrate or squeal.
Thanks for the info! Now looking to upgrade to 1122 or 1115 and need some more info....I'm leaning towards the 1122 because I've got an 07 600 switchback and the price...the 1115 seems to be a bit of overkill for the 600 motor from what I've read and can wear into the clutch faces? Since my sled is set up right now for the 1080....What clutch changes need to made for it to accept the 1122? Thanks!
I had one lose 4 whole top cogs in 40 miles. Dealer gave me a new one. As far as the squealing and creeping, your belt deflection needs to be opened up. I'd adjust your deflection and run it!
Of course, assuming your clutch alignment is correct. If you haven't verified that it is, I highly recommend it! Couldn't believe how bad mine was, and many others have found the same...
TECH TIPS FOR 600/700/800 CFI's & BEST BANG FOR THE BUCK
Thanks!
Mark
From my TECH TIPS Thread, under INCREASING your IQ at the top of this section, PICS are posted there
PRIMARY CLUTCH
1) Check your primary sheave side clearance, should be .010" to .015" with a BRAND NEW BELT, mine & my bud's were .070" from the factory. Increases acceleration and reduces the slamming effect onto the crank.
2) Send your clutch out for balancing, (Preferably after the above step has been completed) noticeably smoother running and extends crank life. SLP ($35.00) and others here on SnoWest can perform this service.
3) Install a new primary clutch spring @ the start of EVERY season.
SECONDARY
1) Install only ONE DELRIN washer under the spring cup (less than $5.00)
2) Install a new spring @ the start of every season
BOTH PRIMARY & SECONDARY
1) Align your clutches (center to center 11.5" EXACTLY, and check for engine crooked, pictures posted in the "link" below as to how the the alignment tool SHOULD contact the front and rear of the secondary) Check this using the SLP or TEAM tool, as the Genuine Gold Plated POLARIS tool has approx .070" of built-in "kick" which is NOT what you want. Check your alignment tool bar for "straightness" with a 3' or so carpenter's level, drywall "T" square, etc., and vernier calipers. mountainhorse reported (2) defective SLP tools. Just because it's NEW doesn't mean it's PERFECT!
A) WITH SLP PUSH LIMITER: 0 to .020" air gap @ the rear of the secondary, (with the front of the secondary touching the alignment bar)
B) WITHOUT SLP push limiter: .020" to .040" of air gap @ the rear of the secondary (with the front of the secondary touching the alignment bar)
You may have to slot the engine bracket(s) to get it PERFECT. On mine and my bud's 07 D7 we had to slot the Mag side engine bracket almost 3/8" to straighten things out. A picture of the Mag side engine bracket is in the link below, do this step ONLY if necessary! Double check your c/c measurements after you get the engine "straight" and then slot BOTH engine brackets an EQUAL amount (if necessary) to obtain the 11.5" center to center EXACTLY.
2) Check and adjust the offset after the above has been completed. This is E-Z to do, just adjust shims on the secondary shaft until the secondary touches the alignment bar. You want approx .030" of free play as well.
3) Lightly sand both the primary and secondary clutches with 180 grit sandpaper perpendicular to the way the belt rides and wipe down with lacquer thinner. Mark the primary with a fat black marker, make a few full throttle runs, and see where your belt rides up to on the clutch.
4) Wash/scrub (plastic bristle brush) your BRAND NEW belt w/soap & hot water, and let dry overnight, sounds weird but it removes the "mold release" compound that would otherwise would get smeared all over your nice clean clutches.
5) Set your belt deflection at 1" - 1 1/4"
Kraven....probably the best info i've seen yet on belt prep and alignment.... polaris should take you to the dealer school to present....wait belt sales would go down!! I ordered a team allignment tool from royal distributors a few years ago and the first time out...fbling went the belt...realligned the old fashioned way and 800-1000 miles per belt no problem. Now I know why...thank you. From what you've shown.....very shoddy manufacturing tolerances from polaris.
