NEW BDX 50 TOOTH STEEL PRO-LITE BOTTOM GEAR
BD-Xtreme
The stock Arctic Cat Aluminum gear has been plagued with problems. They wear out prematurely and produce a large amount of metal shavings in the oil which eventually takes to the chain. We have the FIX for the ALUMINUM GEAR PROBLEM!
Our BDX version Gear is only .5 lb heavier than the stock aluminum gear and it's a whole pound lighter than a OEM style steel gear! We have engineered our BDX gear to be very strong and yet very lightweight.
These gears fit all Arctic Cat models 2012-2020. The 50 tooth bottom gear is what comes on all the mountain 800 and 600 cc models 2013 and newer.
If you have a Arctic Cat Mountain sled, you need this gear!
$79.95
Just installed mine this past weekend. Fitment was perfect. Looking forward to not having "Tin man Jizz " chaincase oil from this point on.
