New AricticFX Sledwrap
B
Bergie
just finished installing my first sledwrap! (I'm not a professional installer)
First off, let start off with #ArcticFX is a great company with a great product!
quoted from their website, "ArcticFX Graphics is a company dedicated to producing the best custom sled wraps in the world. All of our custom sledwraps are made from the highest quality vinyl with exclusive AIR-PASS technology, which not only virtually guarantees you a bubble-free wrap, but also one that will last through the harshest of elements."
First hand knowledge, it truly is easy to install in your garage! They helped me design my custom sledwrap. The quality is worth the price! Check them out for yourself! http://www.arcticfxgraphics.com/
fa
NOT AT ALL... IT WAS SUPER EASY TO INSTALL - Uploading a youtube video now. CHECK OUT MY YOUTUBE CHANNEL
FROM #ARCTICFX website #makeityours
Our graphics are 16mil thick and made with AFX exclusive AIR-PASS© Technology, an industry first. Tiny channels have been cut into our highly aggressive, pressure sensitive adhesive to give you the best vinyl product for power sports in the industry. This means that absolutely NO liquid is required for installation. Our exclusive AIR-PASS© channels allow air to freely move under the graphic and pass through the channels as you squeegee down, resulting in a bubble free install. If you do happen to encounter a bubble, it is highly likely that you will still be able to push the air through these channels
for up to an hour after install. However, depending on the ambient temp, squeegee pressure applied, and/or other environmental factors, you may still need to use the old poke with a pin method. It is important to apply a low to medium heat to all the graphic surfaces, paying close attention to the edges, and run over them once more with a good pressure on your squeegee after you are satisfied with the install in order to close these air channels permanently at the time of installation. While the channels will eventually
close on their own due to the aggressive nature of the adhesive, in this way you can be certain you will not have any immediate issues. Please allow 24 hours after installation to achieve a full bond to your plastics.
