New 2015 M8000 162 - Fully built - SLP Stage III
BLKCAT
This was one of my personal demos last year. Due to scheduling issues and low snow in our area it has never seen snow. Will be sold as factory new with factory warranty. Price reflects all available rebates at this time. Many extras and fine details not listed below. You will not find one nicer or as well put together as this.
Follow link for more pictures:
http://www.bobfeil.com/new_vehicle_detail.asp?veh=395866&pov=4195876
This machine has it all and was never ridden. Started out of the crate as a 2015 M8000 162 Sno Pro then was built from there.
*SLP Stage III Kit - See below from the SLP discription. (If horsepower is your desire, this is the kit for you. It delivers an additional 14.6 HP, 5.7 Ft/lbs of torque, and reduces weight by 20.8 pounds. The real proof is in just how well it performs in the field. From the second you touch the throttle, this engine snaps right to attention. It pulls extremely hard throughout the midrange and legs out incredibly well on top-end leaving most other naturally aspirated sleds of this caliber, as well as many pump gas turbos GREEN with ENVY! For additional benefit, upgrade to the Power Commander V with ignition timing manipulation capabilities and SLP pre-programmed map. Refer to Dyno Charts for more information on these gains. Stock cylinders, head and exhaust valve guillotines will need to be sent to SLP for modification. Note: The Power Commander V supplied in this stage kit has two maps installed into it. One map for using ethanol fuel and one map for non ethanol fuel. It is recommend that a Map Switch (#70-153) be purchased in addition to this kit to allow you to toggle between maps based on the fuel being used.
*Boysen Reed Kit
*BIkeman Secondary Clutch Kit
*Bradley Torque Arm Kit
*SLP Mowhawk Skis
*Fox Evo Float 3 Shocks
*Mountain Fit Hood
*Ridgid Headlamp
*Pro-lite Front Bumper
*Pro-lite Running Boards
*TKI Belt Drive
*3" Powerclaw Track w/7 Tooth Drivers
*Fly Bars w/Switches Relocated
*Zbros Steer Post
*Skinz Snow Flap
*Stomp Tank Grippers
* Mountain Tec Blow Hole
Bob Feil Boats and Motors
2131 Sunset Hwy
East Wenstchee Wa
509-884-3558
www.bobfeil.com
Facebook : FeilsSledWerks
$18000
