New 2009 Dragon Holdover with or without turbo
SNOW JW
New Dragon 2009 163 White holdover with warranty. Sled $8600
Also no turbo installed but can include it with a BD 2010 turbo system with the below for $12,900
Also willing to drive a ways and help with any paperwork if needed to cross the boarder into Canada have recall letter in hand as well as all paperwork needed.
Located in Belgrade MT
E-mail is snowjw3090@yahoo.com
406-922-5454
The new 2010 kit would include
Turbo kit with Die bent and Laser cut parts for perfect fit and finish. Also as you install the kit each step you fallow in the instructions you open a bag with the parts for that step making it easy to install and understand.
Airbox is also bolted and all seals are made with O-ring seals for easy install and no boots to blow off with hose clamps
Water Cooled turbo kit
Oil tank that has a new design for 2010. The reason for the upgrade is to give even better performance and oiling in all types of riding weather your sled is upside down or not it will still perform flawlessly so this makes it the only oil system on the market to do so without oil smoke wile upside down and in any angle. This new system also installs in very short order with better looks and finish. Pics are not on my website yet but should be up soon of the new upgrades.
Air Density Advantage System
Simple tuner programming
Lightweight muffler kit with tunnel dump system pipe size has been tested to get the best performance results. Also this system has great sound but is not real loud or annoying like some turbo kits can be.
New Electronic Boost controller systems includes the fallowing
LED screen that is easy to read and will adjust to light conditions weather you are night ridding or day riding
Built in altimeter so you can keep an eye on elevation
Has auto boost adjust to keep you at the same HP level as you go up and down the mountain without the need to worry about your octane as it will only raise the boost just enough to keep the same HP level as you go up and down the mountain so no need to worry about turning the boost down as you go down the mountain.
Also raise your boost level with two simple push buttons on the gauge simply push in your desired boost level say 7.5 or 9 and it is exactly that no more guessing were your boost will be at.
“push to pass” this is a bottom that will come with the kit and you can put on the left had bar just like a nitrous button so say you have the octane to run 12lbs but you feel and love the way 8lbs feels boondocking but you pull a shoot or race a friend and need a little more HP simply program the box for 12 lbs or whatever boost you want on the button and raise your boost only wile you are on the button.
Full clutch kit
Koso Gauge kit not as cheap as AEM but waterproof and a very high quality gauge.
Full side panel vent kit and intake vents as well as clutch vents
