New 12 pro 800 belt squeal
J
jdrice
Got to ride my new 12 pro 800 for the first time tonight and my belt is squealing really bad so took the belt off and the belt is staring to get chewed up on in inner cogs any ideas what's causing this ?
I suggest you chew your dealer's butt for not adjusting the belt deflection correctly. It should be set at 1 1/4". The info how to set it is in your owners manuals.
Your clutch belt is getting chewed up? Loosen it up on the secondary with the nut and allen bolt. I'm not sure why it would be that out of whack but you could also check the belt alignment. Do you have pics?
You can't be referring to the drive belt because the 2012 doesn't have one.
This is what "PREP" Work is for!!!
Congats you caught it in time before making a huge problem!!
Some may say its your dealers Fault... But Really "WE should Read the owners manual"
Lots of good answers in there if you actually open it and Look at the pics!!
What i was never good at Reading!!
