Needed: NEW Yellow Injector in Alberta
X
XP2009
New member
Hey guys, I am having trouble with my 11 pro with a 12 Silber turbo kit. We have tracked it down to PTO fuel injector. There are none in Alberta that we can find. I have a trip to Vale planned for next Tuesday; any help would be great. THX
Is it the PTO injector for the silber fuel rail or the factory polaris injector? Where are you located?
It is the factory yellow injector I'm looking for. We did re-plug in the factory injector harness to remove the fuel controler as a possibility. The issue is still there. We have good fire (and changed plugs), good compression (120 per side), fuel is passing PTO in the rail to get to MAG side so we suspect fuel (pump or filter)is not the problem, and of course confirmed its not a controler issue.
But the sled will run like it has a dead plug. No fuel is getting to the PTO cylinder. I'm located in Fort Mac.
I have been in contact with someone with used yellow injectors. But not sure how long they will take to get here.
