need trany t case help??????
truck below
it has a getrag 5 speed and a ford transfercase
its like it comes out of gear then goes back in on its own. makes a sweet grinding noise when it does it. does it mostly in the morning when its cold or the oil is not all stired up? i did not put the stuff in i got it this way? im pretty sure its in the t case but what could be going wrong?
i though it was poping in to N in the t case so i put a strap on the leaver so it can't move. but it is still doing it?
any help????
__________________
1983 F-350 Crew cab 4x4 4.10 5 speed 90 cummins 12v, turned up pump, centerforce clutch, stright piped stack on its way.,97 alcoa ford wheels, with custom built flatbed 265 85 16s running on 50% UMO
Any idea what transfer case it is? If it's a 1356 they had a TON of issues with the planetary units coming apart and they'll free wheel when you get outta the gas. Easiest way to tell is put it in low range and see if the problem goes away. When you do that it drops the reduction hub into the planetary unit and locks it up. Let me know if that fixes it, i got a ton of parts for those here at my shop if you need any.
Then it ain't a 205, them bastages are cast iron and freakin heavy. If it's aluminum it will probably be the BW 1356. Shocker is right, it's probably in the planetary set. Try it in low and see if it still happens. Also does it happen in all gears?
