A
Arctic Thunder
Ill be calling Shain also but wanted to get some opinions here also.
Have a Twisted kit running the 3076 Race gas turbo on a 09 M1000. Running 10psi boost on 100LL av gas.
Attitude Box controller. (Red/Blue is the boost setting on this box)
Green = .5
Yellow = .5
Red = .5
Green Blue = .5
Yellow Blue = 1
Red Blue =5
40psi fuel pressure at idle. 1-1 ratio, goes to 50 psi at 10 lbs of boost.
-5 deg F
7500' elev
11.8 AF on a hard pull
12.5-13.5 on the trail no load
Sled will pull hard from a dead stop, but if I back out of the throttle even a little bit it will NOT pick it back up. I have tried about every setting I can think of.
I have moved the Yellow blue transistion point from .5 to 6 and it will not run. Much worse as I move the transistion point up.
I felt I had it pretty close last weekend, but now this weekend it is right back where I started. Last weekend I had the transition point to high and when I backed out of it it wouldn't pick it up. As soon as I dropped the transision down to 1.5 it freeeking ripped. So I thought I had it nailed. Well this weekend back to the same old crap. again I have bounced the Yellow/blue all over the map.
I am open to any ideas. I started with Shains base settings it wouldn't even run. I have compared my numbers with others and my numbers are a lot lower then theirs. But my AF numbers are right were they should be.
So give me some ideas.
Thanks.
Thunder
Here is a video clip.
http://www.youtube.com/watch?v=m2a0cKVKImU&feature=youtu.be
Green = .5
Yellow = .5
Red = .5
Green Blue = .5
Yellow Blue = 1
Red Blue =5
-5 deg F
7500' elev
Thanks.
Thunder
