Need some of that snowest wisdom...
A
Aug
So I bought a new oil pump and some new Gravity works throttle/oil pump extended cables. How do I change how lean or rich the oil pump runs? Right now it's about 25:1, if there is a real way to measure with these cable how much slack is the right amount? I know if I tighten it the pump should burn leaner, I just would like a better way then guessing. I am getting tired of carring all this oil and I'm sure it's not helping the performace.:rolleyes:
I am assuming it is a mmax that would be 21 mill meters between the cable end and the adjustment that is in the middle of the cable with the cable pulled tight out of the seated position You shuold have 21 mm of cable showing when it is pulled tight hope this helps you
Yeah I know that but the new cables don't come apart in the middle. It has an adjuster but the ends are sealed on unlike the old one.
