need some ideas for clutching on M8
i have a 07 m8 i am not sure what to do for clutching. the sled has a black diamond air box bikeman high compression heads y pipe and can and will have a pc 5 on it. ride at sea level when theres snow otherwise ride at 8500 to 10000 ft on trips. wondering if i would be able to get away with the adjustable weights or if i would need to do more to the clutches to get it to work well with the extra power the motor is putting out. the clutching is stock now. any help would be great. thanks
Contact RKT .. if you have a little coin Kelsey will steer you right.
Probably recommend a secondary helix kit, and you can't go wrong with Cutler adjustable weights. That combo will give you a lot of adjustment capability to get it dialed in just the way YOU like it. :D
