D
ddog96mn
New member
So I was trying to pull my clutch today, and my dad has this puller, its basically a brass shaft, about the size of the hole in the primary, and then a big bolt (not sure what size) but anyhow the bolt threads into the clutch hole and it is supposedly supposed to pull the clutch off as it is threading. so i stuck it in there, started threading the bolt, then used my impact air wrench and put the bolt allll the way until it was up against the clutch, the primary didnt move one bit, so i un threaded the bolt, took a look in and i saw brass peices and then the puller way the F**k in there. is this normal, or did i do something wrong? what could i do to solve this problem? thanks
