T
tcpeterson
Ok, so details on the sled:
09' M1000 162, Full SLP exhaust with Power Commander III, have about 2400 miles on it now. Ride mostly 5000-7000 ft
Last time I rode it (May of 2011) it ran great no problems what-so-ever. Put some star-tron in the fuel and stored it for the summer. It's been a busy winter so i'm just now getting some rides in. The only change I made was swapping out my Avenger II gauge for a Koso....
What i'm experiencing is that it seems really rich on the bottom and mid range. On the top end i'm pulling 7650 for RPM's and about 1160-1170 on my egt's.
The weird part about it is that in the low and mid range the egt's are all over the place, even caught them around 1300 once but only on the PTO side??? the mag side was at like 900ish??? When i pulled the plugs it appears that they are washed clean.... to much fuel??? excess fuel burning in the y-pipe?
Today going down the trail the sled would load up occasionally and i'd have to work the throttle to open it back up, sometimes it seamed to be going into limp mode
So what i've done:
Checked spark plugs and wires, getting good spark on all 4.
Cleaned and check power valves
Baro-tube is clear
Exhaust is clear
Checked reeds
Looked at piston wash a couple times, pistons look good. Wash the first time was non existant, they looked clean and almost brand new. The second time after running it in the shop for a while there was good color.
What i'm still wondering?
Injectors stuck open?? (Just got done running a fresh tank of 91 ethanol free fuel and a bottle of sea foam through it)
ECU?
TPS?
Pipe temps sensor?
I am looking for any help that i can get from other experience. I tried using the search function but felt like i was going in circles.
Thanks in advance
So what i've done:
Baro-tube is clear
Exhaust is clear
Checked reeds
ECU?
TPS?
Pipe temps sensor?
Thanks in advance
