sled- 04 edge 800 slp single/ported /attcc/slp head/bored carbs
(5500'-8500' elivation)
problem- it loads up real bad when i try to give it 3/4-full throttle
then it clears out and runs good till i let off and slow down and then try to get back on it then it misses/stuters then will clear out once i can hold it full for a bit (idles fine 0-1/4 throttle seem fine)
things i've tried or changed - checked all wiring(unhooked the hood /brake light/hand heaters /throttle safety = no change
checked plug wires changed plugs = no change
changed jeting - i have the attcc(compinsator) its always worked good but last year i kept jeting up because i thought my plugs looked a little light in color so after a few changes by the end of the year i had 490/500 jets in it
(seemed to big but it ran fine)
so i'm thinking its to rich so i jet down and down to 440s (little change)
so i'm thinking the attcc is messed up so yesterday i said screw it and put 400s in it and unhooked the attcc it was better but not fixed?
so pulled a good climb and checked the plugs too light(lean) for my liking so i'm thinking it can't be to rich but don't have anything left to try so i hooked the attcc back up to see and no change
any help would be great guys
it does'nt seem electrical it seems like carbs but i'm stumped if the only other piece of info i got is that it seems better when i come down in elv. so again it seem like a rich thing but with 400s the plugs looked tan not chocolate??
thanks garth (and thats the rest of the story)
