Good links. Lots of information there.
Those tighter tolerances used in production of Avgas result in less chance of water contamination, the TEL makes it much more resistant to Pre-ignition and Detonation, along with less corrosion on rubber, and less build up. Wish all our fuel was that good and consistant.
But I'm sure that all adds to the cost, which makes sense to pay in an airplane as the engine it's running is supplying the thrust to help people escape gravity and all
Didn't see any difference in octane rating systems in there just a different way to achieve it; ie alchohol type additives versus TEL. Did I miss something?
Either way 100LL works real well with 4 stroke airplane turbos which I'm sure are a whole different ballgame (lower compression, and probabaly a million other differences) than the turbo snomobile engines, 2 or 4 stroke.
Didn't mean to derail the thread.
If it's as easy as "the higher the octane fuel you run the more boost you can produce in the same motor"
I guess everybody should be looking for some of that purple dyed stuff.
115-145 octane would surely RIP!
