Need help
squba steve
New member
I have an 08 m1000. My throttle override switch is acting up. Its shutting my sled off when I let off after a hard pull. Is there a way to delete this switch or dose anyone know some corective action to fix this?
I think you can just disconnect the kill switch and use the key. That is what I did on my 1M. I would think that is still the same set up.
throttle cable
check your throttle cable adjustment. You might have too much free play.
Throttle safety Switch
On the throttle safety switch. if you take an 8 MM torx bit and take you assembly apart you can unplug it. You probably just need to tighten you throttle cable.
