2001 Summit X 800 High mark has a hard time starting, almost like its not getting enough fuel to start, we had to keep pouring gas in the cylinders to get it started then it would run. Any ideas???
How much compression do you have?
Thanks I will check that to.
Today I was putting everything back together and found the sled to be running on one cylinder sorta.
DOES ANY ONE KNOW HOW TO TEST A COIL AND WHAT THE SPECS SHOULD BE FOR A COIL 512059363 2001 800 HIGHMARK X
I PUT A TESTER ON THE SPARK PLUG WIRES AND ONE SIDE IS REAL ERRATIC (LIGHTS UP THEN STOPS THEN LIGHTS AGAIN) . SOUNDS LIKE THE SLED IS RUNNING ON 1 CYLINDER, sorry for the caps forgot I had it on
Thanks
your rings are shot. out in wiseco rings and pistons
Where the heck did that come from? Pistons and rings? Not
I did it, it was between 110 and 115
