Need help with Chaincase issue
R
richyrich
I have a T-apex with a rolled chaincase, down 2", back 2.5. When I rode this spring, my first and only ride on the sled, i had a small amount of oil in the belly pan in front of the chaincase.
I was told the vent for the chaincase is located in the dipstick and when its rolled down and back it can at time blow oil past the stick grommet. Is this true or do I need to be looking at the turbo or turbo lines. ??
Yep. Mine has the same D&R and it does the same thing. It spits a bit from the vent hole if it is over full. Don't use the stick as a gauge. When you drain the oil measure and put in the right amount speced in the manual. With the sitck angled you will never get the right amount in using the dip stick.
Sap
