i need some help this sled is stuck at 3400rpm and wont go any lower will rev up but wont come down past 3400rpm. I have tried ether on crank seals and also had airbox off checked the throttle body and adjusted the TPS to proper specs in manual
Is that .975 Ohms at closed or wide open???
I would think either way should work, and you are right Eric, setting with idle screw backed out to get base setting and then using your screw to set to a specific volt/ohm reading..as long as you are using the correct settings for either volts or ohms...I will go look and see what the pro procedure shows...BRB......The stuff I quoted is from the IQ chassis, maybe the Pro is different. I haven't looked into the Pro setings. Even if the Pro is a different procedure wouldn't you still set the idle after the baseline was established using your multimeter (Ohms of Volts) and then adjust idle to values rather than just turning the idle screw and watching the tach.
So is it running good now? EW
also, on the idle settings if you set to the low side(.937) it will idle lower,if you set to the high side(.952) it will idle higher....Ok, just read the 11 online dealers manual...all 6-8 cfi motors in 11 call for using volts to set tps..base settings are between .693 and .708 VDC..Idle settings are 600-.942 to .957 VDC...........800- .937 to .952 VDC.....also, same throttle sync as the earlier cfi motors..but it does say there is no reason to adjust unless its obvious its been tampered with and shows how to eyeball the plates to check if they look ok .......hope that helps..
DMK, I would recheck yours..sounds like if it was set with ohms it could be off....you might want to verify its settings are right on a volt setting...
