Need help sled bogs
I just bought a 2014 xf high country when I bought it it didn’t have a primary clutch so I bought a new primary clutch and I went for a ride when I go slow it doesn’t bog but when hit the gas it bogs allot the belt it a bit loose but the shevs on the secondary are closed all the way so the belt it maxed I also tried another belt and a secondary off a m8000 and messed around with the spacers on the bolt for the secondary the belt is still a bit loose
Check motor mounts to see if engine is where it belongs, torn or off center ones replace. Loose belt needs addressed.
Just to throw it out there, and since the sled didn't come with a clutch- Have you ensured your using the correct, and OEM belt # ?
A belt that is too loose can actually cause performance issues, such as clutch slippage or loss of power when you accelerate. It is essential that the belt is properly tensioned to allow efficient power transmission between the primary and secondary clutch.
