need help programing boondocker box
hi i have a 09 m8 i have a speedwerx pipe and y pipe and high flow in take and i have an slp high flow in take and an ornge and white spring for the primeary clutch and the boondockers control box im about 3000 feet if any of u know where Jackman ME is thats where i live i would like any help i could get
thanks
if your looking for the numbers to put in your boondocker i would call speedwrex and see wat they recomend i have a full d&d setup and i called them and they gave me there settings for the boondocker and my sled runs alot better now
ya i called them
and they gave me the same numders then some one elce told me to take off the y pipe and put the stock one back on and now there numbers work some what its not showing the blow up code but there still is a bog or if i stop and talk or just let my sled run for a little its like it lods up
the numbers are
3 5 10
3 5 10
5 5 11
14 14 14
14 14 14 what are ur numbers
Those numbers look way to fat! Go down to like:
0,0,0
0,2,3
2,5,3
3,8,6
10,16,18
Run these and check plugs. Should be close.
Aaron
Speedwerx gave me the same numbers n they are very rich. I have a 09 HCR speedwerx full pipe and RKT head. I haven't had time to start messing with the box yet to lean it out. But Im going to start will those numbers work for low alt too?
