Need help on Clutching 700 himark
Can anyone point me in the right direction on where I can start on a clutch set up for a 151 700 summit. I have no clue whats inside of the clutch. The guy who set it up is a tottal idiot. This sled is running like crap. I've had it in his shop twice and it still runs like crap. Still has no power from 3/4 to full (also no rpm change, just kinda bogs on the top end).
I guess my question is does anybody rember what setups they were running inside their 700's back in the day? Thanks any advice is apriciated.
700
299 ramps, purple/ yellow spring (130/230) Hollow pins clicker 3. This works great from 4K to 10K
He means 4k to 10k elev. I ran 293 ramps, 230/340 spring, 14g adjustable pins, Team Sec, red/black spring, 54/38/46 helix. 2k to 4k elev. If its bogging from 3/4 to full I would guess you are to rich.
Geez, I can only recall...
287 ramps
Light adjustable pins approx 17 grams
mag arms
160/320 primary spring
gear down to a 19 top tooth
you will never blow a belt.
white spring on C5 on secondary
Goodwin teflon buttons.
adjust clickers to 7850... I believe.
BJ has the real deal setup.
What elevation? Set-up I run @ 9,500-11,500ft., 287 ramps, 160/290 pri., 11.3grs., clicker 4. Secondary 43/40 Black Ice, Goodwin Blue set B-6, 19lbs.
Dave
