B
Brotha NOS
New member
I have an 08 Rev XP with an 885 Big Bore. I have switched jackshafts in order to accept other secondary clutching. I ordered a Team Secondary set up with the recommendations of the supplier. It came with a Black/White Spring (160-260) and a 420767 Helix (48-44ER F 46-42ER F). With this set up there is good performance out of the hole and in mid range. But under load climbing the RPM of the sled drops by 400 rpm. Through different settings on the TRA I was unable to correct the RPM reduction. I changed the spring to a Black/Red (155-122). With this spring the hole shot is good but the mid range is linear in power (Let off the power and hit WOT it is slow to react) but I was able to hold RPM climbing. There are so many helix and spring options I am not sure where to go from here. I e-mailed Team last week and have yet to get a response. Any ideas?
