Been working on a Buddy's 03 800 mountain cat that hasn't been used in 3 years , the driveshaft broke on the clutch side behind the bearing and tore the tunnel. Replaced the tunnel ,driveshaft,bearings and chain. Cleaned the fuel tank and replaced the fuel pickup lines. Then the fuel pump wouldn't work so replaced it too. NOW the PROBLEM is no fuel going thru the injectors, I have fuel to the top of the injectors on the fuel RAIL. Is there any way a guy can clean these.
I can make it run by putting gas in the cylinders but after gas burns out of the cylinders it dies .
Any help would be greatly appreciated.
