Hey guys I'm new to the forum and the sled to be honest. I've done a lot of research over a few different forums but can't seem to find the right answer for my specific sled, 09/shorty/turbo
I have a 2009 nytro with a rear mount mcx 180 kit on it. The previous owner was running a 1.25" track with studs and the studs chewed the aluminum bar and the tunnel protectors chewed the track up pretty good where they should be notched... my question is I would like to run a bigger lug track no studs like a 1.75" or minimum 1.5" (if I absolutely can't go to 1.75")
If the tunnel protectors are hit the track now what's gonna happen with a bigger lug? Let alone the aluminum bar. Is the suspension possibly an issue? I know people say you have to remove the protectors for 1.75" but then the turbo is exposed??? I know I can do smaller drivers like 8 tooth but that only helps clearance at the front cooler which I'm not concerned about, can't find anything on people doing drop brackets or mtx rear brackets
How do guys with shorty's and turbo run loose tracks with anti ratchets or put big lug tracks then???
I was also hoping to put a star suspension 128" relocate in as well and then go to a 128x1.75x15 track but will the locate effect anything help or make worse?? Has anyone done this
Thanks glad to be apart of this forum community!
