So, I just pulled my old one out and put the new one in. Found out from a similar post here:
http://www.snowest.com/forum/showthread.php?p=1114049#post1114049 that mine is a CR-Racing post.
ANYONE HAVE A WEB ADDRESS FOR THEM?
Just wanted to ad a side note...
I pulled mine out through the bottom but it was a major PITA. Mostly due to the fact that I had it up on saw horses, not a "real" snowmobile jack, so I had MANY clearance issues getting it out. Since it comes out the bottom, you will need A LOT of "wiggle room" to spin it and twist it and move it side to side, back & forth etc. I had way too many cross braces etc. set up between my skis setting on the saw horses so I had to drop it nearly straight down & out which was NOT good! Would have been MUCH easier if I could have wobbled it around a lot more. So, if anyone else reads this, keep that in mind when setting your sled up in the air.
Now, that said, when I put the new post back in, just for ****s & giggles, I tried to put it in from the top... slipped right in NO problem, MUCH easier! Might be because when re-installing it's in FRONT of the hoop instead of behind it, so you wouldn't be able to remove the OEM out the top? Don't know I didn't try but I would recommend if doing it again, try to pull the OEM one out the top and see if it works? If not, then Jack up, remove the belly pan and go through the bottom. Just leave a wide birth around the bottom where you will drop it out, so you can finagle it around a LOT!
EDIT: or just tip the sled on it's side and go out through the bottom rather than jacking it up.
Haven't finished yet, just got the bottom mounting done, now have to finish up the other mods I'm doing so I can lower the sled to finish it up. I can't turn the bars right now the way I have it jacked up... it's sitting on the skis, on 2x4's, across saw horse...
Anyway, thanks again. will post a final, final when I'm done.
Here’s your side-by-side pix Spring Snow Hero.
Happy New Year to you & yours!
biGjOhn
